nikitaspickiy
Вылетает Просмотр архива при попытке экспортировать видео
Добрый день, пытаюсь экспортировать видео и окно программы сразу закрывается. В логах пишется ошибка:
2016-09-26 14:13:00.277 DEBUG root             check_network...
2016-09-26 14:13:01.527 INFO  root             [exporter] start export camera 23 from 2016-09-22(11-50-00) to 2016-09-25(12-10-00)
2016-09-26 14:13:01.802 ERROR root             [exporter] encoder exception -13: avio_open: Error number -13 occurred
2016-09-26 14:13:01.891 ERROR root             [export] error code 13 (write-frame-error)
2016-09-26 14:13:02.053 DEBUG root             [archive] camera 3-0 warning: missing intra frame for 536 (yMkAAD4CNwAAAAAAAArn79MX0gENZxSxsgYUKEKMRREdggAA)
2016-09-26 14:13:02.127 WARN  root             [archive] camera 3-0 error: cannot decompress key frame 536 (yMkAAMIBNwAAAAAAgFC879MX0gENZxSxsgYUKBSVQBGhMwIA)
2016-09-26 14:13:02.192 WARN  root             [archive] camera 3-0 error: cannot decompress key frame 536 (yMkAAMIBNwAAAAAAgFC879MX0gENZxSxsgYUKBSVQBGhMwIA)
2016-09-26 14:13:02.260 WARN  root             [archive] camera 3-0 error: cannot decompress key frame 536 (yMkAAMIBNwAAAAAAgFC879MX0gENZxSxsgYUKBSVQBGhMwIA)
2016-09-26 14:13:02.338 WARN  root             [archive] camera 3-0 error: cannot decompress key frame 536 (yMkAAMIBNwAAAAAAgFC879MX0gENZxSxsgYUKBSVQBGhMwIA)
2016-09-26 14:13:05.356 INFO  root             [exporter] start export camera 23 from 2016-09-22(11-50-00) to 2016-09-25(12-10-00)
2016-09-26 14:13:05.425 ERROR root             [exporter] encoder exception -13: avio_open: Error number -13 occurred
2016-09-26 14:13:05.485 ERROR root             [export] error code 13 (write-frame-error)
Хотя если поставить на экспорт видео длительностью 10 минут, то оно выгружается, но очень медленно, хотя диски стоят быстрые.
Конфигурация системы:
   Operating System: Windows Server 2012 R2 Standard 64-bit (6.3, Build 9600) (9600.winblue_rtm.130821-1623)
           Language: English (Regional Setting: English)
System Manufacturer: Supermicro
       System Model: X9DRW-3LN4F+/X9DRW-3TF+
               BIOS: BIOS Date: 02/06/14 13:39:14 Ver: 04.06.05
          Processor: Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz (24 CPUs), ~2.1GHz
             Memory: 65536MB RAM
Available OS Memory: 65500MB RAM
          Page File: 7123MB used, 68105MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.03.9600.16384 64bit Unicode
Версия сервера Devline 7.1.0
В "Линии", предназначенный для экспорта фрагмент, просматривается нормально?
Нужно обновить программное обеспечение до версии "Линия 7.1.1 RC2" http://www.devline.ru/beta_version/ без сохранения логов и  информации об ошибках.
Если после обновления будут наблюдаться ошибки - пришлите, пожалуйста, сбор  сведений о системе, сделанный с помощью Линии ("Пуск\Все программы\Линия 7.1.1\Сбор сведений о системе") личным сообщением.
 При просмотре 1х нормально, при увеличении скорости программа начинает тормозить.
Обновление не помогло, логи вышлю в личку
Не справляется сервер, вероятно дисковая подсистема.
Логи с ошибками "Линия 7.1.1 RC2" ожидаю.
