kuznetsov_ev 0 Опубликовано 1 Сентября 2025 Версия Linux без GPU 8.4.0 version: 316d93924a7f Подключено много камер, нагрузка 30-50% CPU При наборе таких ошибок с конкретной камерой: 2025-09-01T08:48:35.426416+03:00 b2-video-1 kernel[2554]: [onvif] failed to perform system datetime request for <camera IP>: connect error 2025-09-01T08:48:45.430724+03:00 b2-video-1 kernel[2554]: [onvif] failed to perform caps request for <camera IP>: connect error 2025-09-01T08:48:45.431067+03:00 b2-video-1 kernel[2554]: [onvif] failed to init base services on <camera IP>: connect error 2025-09-01T08:48:45.431228+03:00 b2-video-1 kernel[2554]: [onvif] failed to init services for <camera IP>: connect error 2025-09-01T08:49:30.433207+03:00 b2-video-1 kernel[2554]: [onvif] failed to perform system datetime request for <camera IP>: connect error 2025-09-01T08:49:40.435246+03:00 b2-video-1 kernel[2554]: [onvif] failed to perform caps request for <camera IP>: connect error 2025-09-01T08:49:40.435428+03:00 b2-video-1 kernel[2554]: [onvif] failed to init base services on <camera IP>: connect error 2025-09-01T08:49:40.435521+03:00 b2-video-1 kernel[2554]: [onvif] failed to init services for <camera IP>: connect error 2025-09-01T08:50:25.437960+03:00 b2-video-1 kernel[2554]: [onvif] failed to perform system datetime request for <camera IP>: connect error 2025-09-01T08:50:35.440367+03:00 b2-video-1 kernel[2554]: [onvif] failed to perform caps request for <camera IP>: connect error 2025-09-01T08:50:35.441157+03:00 b2-video-1 kernel[2554]: [onvif] failed to init base services on <camera IP>: connect error 2025-09-01T08:50:35.441294+03:00 b2-video-1 kernel[2554]: [onvif] failed to init services for <camera IP>: connect error 2025-09-01T08:57:37.468081+03:00 b2-video-1 kernel[5151]: [onvif] failed to perform system datetime request for <camera IP>: connect error 2025-09-01T08:57:47.471636+03:00 b2-video-1 kernel[5151]: [onvif] failed to perform caps request for <camera IP>: connect error 2025-09-01T08:57:47.472078+03:00 b2-video-1 kernel[5151]: [onvif] failed to init base services on <camera IP>: connect error 2025-09-01T08:57:47.472203+03:00 b2-video-1 kernel[5151]: [onvif] failed to init services for <camera IP>: connect error 2025-09-01T08:58:32.475718+03:00 b2-video-1 kernel[5151]: [onvif] failed to perform system datetime request for <camera IP>: connect error 2025-09-01T08:58:42.477243+03:00 b2-video-1 kernel[5151]: [onvif] failed to perform caps request for <camera IP>: connect error 2025-09-01T08:58:42.477448+03:00 b2-video-1 kernel[5151]: [onvif] failed to init base services on <camera IP>: connect error 2025-09-01T08:58:42.477542+03:00 b2-video-1 kernel[5151]: [onvif] failed to init services for <camera IP>: connect error 2025-09-01T08:59:37.482809+03:00 b2-video-1 kernel[5151]: [onvif] failed to perform caps request for <camera IP>: connect error 2025-09-01T08:59:37.482933+03:00 b2-video-1 kernel[5151]: [onvif] failed to init base services on <camera IP>: connect error 2025-09-01T08:59:37.483027+03:00 b2-video-1 kernel[5151]: [onvif] failed to init services for <camera IP>: connect error 2025-09-01T09:00:22.485196+03:00 b2-video-1 kernel[5151]: [onvif] failed to perform system datetime request for <camera IP>: connect error 2025-09-01T09:01:17.490471+03:00 b2-video-1 kernel[5151]: [onvif] failed to perform system datetime request for <camera IP>: connect error 2025-09-01T09:01:27.492329+03:00 b2-video-1 kernel[5151]: [onvif] failed to perform caps request for <camera IP>: connect error 2025-09-01T09:01:27.492903+03:00 b2-video-1 kernel[5151]: [onvif] failed to init base services on <camera IP>: connect error 2025-09-01T09:01:27.493014+03:00 b2-video-1 kernel[5151]: [onvif] failed to init services for <camera IP>: connect error 2025-09-01T09:02:22.497773+03:00 b2-video-1 kernel[5151]: [onvif] failed to perform caps request for <camera IP>: connect error 2025-09-01T09:02:22.497881+03:00 b2-video-1 kernel[5151]: [onvif] failed to init base services on <camera IP>: connect error 2025-09-01T09:02:22.497975+03:00 b2-video-1 kernel[5151]: [onvif] failed to init services for <camera IP>: connect error 2025-09-01T09:03:07.500069+03:00 b2-video-1 kernel[5151]: [onvif] failed to perform system datetime request for <camera IP>: connect error Или сервис Линии перестает отвечать, или даже завешивает систему так что ни дисковые ни сетевые операции перестают работать камера EZ-IPC-T3B50P-0280B Кроме того такая же проблема наблюдалась на другом объекте, с 8.X версией. Т.е. реакция именно на какие то неверные данные с камеры, а не когда она физически отключена Поделиться этим сообщением Ссылка на сообщение Поделиться на других сайтах В
Станислав 0 Опубликовано 1 Сентября 2025 Здравствуйте! Пришлите сбор сведений о системе [sudo /opt/line/bin/sysinfo] личным сообщением. Укажите дату и время падения. Поделиться этим сообщением Ссылка на сообщение Поделиться на других сайтах В
