zotovkem
Не стартует HTTP сервер Линии на 85 порту.
Попробовал изменить порт со стандартного на 85
Рестартую линию sudo systemctl status line
Проверяю статус sudo systemctl status line
Б≈▐ line.service - Line, digital surveillance system
   Loaded: loaded (/lib/systemd/system/line.service; enabled; vendor preset: enabled)
   Active: active (running) since п║я─ 2018-02-07 16:27:45 +07; 2min 1s ago
 Main PID: 2477 (kernel)
    Tasks: 89
   Memory: 38.2M
      CPU: 388ms
   CGroup: /system.slice/line.service
           Б■■Б■─2477 /opt/line/sbin/kernel --user=line --share-dir=/opt/line/share/line --var-dir=/var/opt/line
я└п╣п╡ 07 16:29:20 kmr_srv_video kernel[2477]: [http] failed to perform: Timeout was reached
я└п╣п╡ 07 16:29:20 kmr_srv_video kernel[2477]: [onvif] failed to perform system datetime request: 2
я└п╣п╡ 07 16:29:25 kmr_srv_video kernel[2477]: [http] failed to perform: Timeout was reached
я└п╣п╡ 07 16:29:25 kmr_srv_video kernel[2477]: [onvif] failed to perform caps request: 2
я└п╣п╡ 07 16:29:25 kmr_srv_video kernel[2477]: [onvif] failed to init services: 2
я└п╣п╡ 07 16:29:25 kmr_srv_video kernel[2477]: [media] nvi connection error on Camera 2
я└п╣п╡ 07 16:29:26 kmr_srv_video kernel[2477]: [http] failed to perform: Timeout was reached
я└п╣п╡ 07 16:29:26 kmr_srv_video kernel[2477]: [onvif] failed to perform caps request: 2
я└п╣п╡ 07 16:29:26 kmr_srv_video kernel[2477]: [onvif] failed to init services: 2
я└п╣п╡ 07 16:29:26 kmr_srv_video kernel[2477]: [media] nvi connection error on Camera 1
Проверяю слушает ли порт sudo netstat -anutp
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:9780            0.0.0.0:*               LISTEN      2477/kernel
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      1134/sshd
tcp        0      1 192.168.30.251:35608    192.168.30.70:80        SYN_SENT    2477/kernel
tcp        0      1 192.168.30.251:34410    192.168.30.61:80        SYN_SENT    2477/kernel
tcp        0    404 192.168.30.251:22       192.168.30.13:64246     ESTABLISHED 1351/sshd: user [pr
tcp6       0      0 :::22                   :::*                    LISTEN      1134/sshd
udp        0      0 0.0.0.0:9877            0.0.0.0:*                           2477/kernel
Если проделать все с другим портом, например 9785 все нормально работает.
Подскажите куда копать.
Только
sudo systemctl restart line
Порт занят может?
А фактически при открытии 127.0.0.1:85  что открывается?
И версию не указали
Изменено пользователем Fox
Вот такую ошибку выдает на sudo systemctl status line
   Active: active (running) since п║я─ 2018-02-07 16:45:31 +07; 3s ago
 Main PID: 1476 (kernel)
    Tasks: 90
   Memory: 67.2M
      CPU: 775ms
           Б■■Б■─1476 /opt/line/sbin/kernel --user=line --share-dir=/opt/line/share/line --var-dir=/var/opt/line
я└п╣п╡ 07 16:45:31 kmr_srv_video systemd[1]: Stopped Line, digital surveillance system.
я└п╣п╡ 07 16:45:31 kmr_srv_video systemd[1]: Started Line, digital surveillance system.
я└п╣п╡ 07 16:45:31 kmr_srv_video kernel[1476]: [kernel] start (version: d3faad4b1b6c)
я└п╣п╡ 07 16:45:31 kmr_srv_video kernel[1476]: [kernel] profile successfully loaded: Default
я└п╣п╡ 07 16:45:31 kmr_srv_video kernel[1476]: [http] failed to start server: I/O error
Как еще проверить на занятость порта кроме netstat?
Версия Ubuntu 16.04  x64
Версия Линии 20180123 x64 коммерческая.
Открыть Mozilla Firefox и посмотреть. И прикрепляйте скриншоты или убирайте под <>
Хотя вот это
какой-то конфликт вроде.
Вам, честное слово, заняться нечем? :blink:
С 1 по 1024 порт вообще трогать нельзя, а Вы на них что-то садить пытаетесь.
Есть назначенные порты, их и используйте. Не нравятся - штрудируйте интернет и не занимайтесь порнографией, а то понастроят - потом понять не могут, почему не работает.
Есть порты и протоколы, которые официально, неофициально или полуофициально привязаны за каким-то сервисом - значит не надо их трогать.
https://ru.wikipedia.org/wiki/Список_портов_TCP_и_UDP
Я бы у таких пользователей вообще админские права отбирал, даже при условии, что они сами администраторы.
Да, порты до 1024 в Linux - привилегированные. Просто так их использовать не получится, но, если очень нужно, то, конечно, можно. В сети много информации на этот счет, например, вот https://stackoverflow.com/questions/413807/is-there-a-way-for-non-root-processes-to-bind-to-privileged-ports-on-linux
